I need front audio ports for Headphones and Mic.
I have an Asus M3A32-MVP Deluxe Wifi-AP motherboard
I have the following slots free:
2x external floppy drive bays
1x CD/DVD/Optical drive bay
I have a 7.1 surround sound setup connected to the back panel ports from onboard sound, from the motherboard and what I would like is front ports for the mic and headphones, so that when Im gaming/mix/match I can simply plug in the headphones/headset and use it that way (with obviously the speakers being cut out due to connection by headphones)
I would prefer it this way, but can consider buying a USB headset?
When I built it, I had XP, XP64 and Vista, so I needed a floppy drive and brought one with a card reader built in on it. I now only use windows 7, so no longer require the floppy drive, but card reader is used every once in a while.
Whats the best way forward/product to use?
Thanks
Thanks
