Asus EAH4350 SILENT/DI/512MD2(LP) help!!
Hi..
I would to upgrade new graphic card for my pc that is:
- HP DC7600, Running win 7 Ultimate 32 bit
- 1.5GB ram..
I know its a noob pc.. :(
Anyway my mobo got 1 slot pci-express..
I found one that i think suits me that is Asus EAH4350 SILENT/DI/512MD2(Low Profile)...
But the pcie version is 2.0.. Mine i think is pcie version 1.0..
Does it backward compatible?
I search from the internet that pcie 2.0 is backward compatible with earlier version except with VIA mobo..
Just want some confirmation from u guys.. Does it true?
And my PSU is 350 watt...
And i think the card will consume low voltage usage..
CAN MY PC RUN IT?
I hope so can... :(
Plsss help me guys...
3 answers Last reply
More about asus eah4350 silent 512md2 help
  1. your case, is it mini-tower?
    yeah, 350W will be enough for 4350.
    yes, pcie 2.0 is backward compatible with 1.1 or 1.0, so don't worry.
    But are u sure there's no other card that will fit on your case?
    4350 is a weak card for gaming... :)
  2. Can recommend me?
    That suits with my PSU..
  3. then yes, u will be okay with that low profile card...
    just check your case, make sure the card would fit on your case... :)
Graphics Cards Asus Graphics
