I'm trying to fing a gaming rig that is futur proof (DX11) , i got several rigs but this is my best one. I need your help in this :
-good for gaming (ex:cod mw2) ?
-Are components compatible ? (pretty sure they are)
- can i find better/same for cheaper?
- good rig ? in general.
-did i forget something ?
Build:
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153& =cm_re=Gaming_Case-_-11-147-153-_-Product = 60$
Mobo : http://www.newegg.com/Product/Product.aspx?Item=N82E16813128405 = 105$
CPU : http://www.newegg.com/Product/Product.aspx?item=N82E16819103694 = 85$
Video Card : http://www.newegg.com/Product/Product.aspx?Item=N82E16814150465&cm_re=radeon_hd_5750-_-14-150-465-_-Product = 165$
Optical Drive:http://www.newegg.com/Product/Product.aspx?Item=N82E16827140041&cm_re=double_layer_dvd_burner-_-27-140-041-_-Product = 35$
Ram:http://www.newegg.com/Product/Product.aspx?Item=N82E16820231276 =115$
PSU : http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015 = 80$
HDD : http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185 = 90$
Total w/ Shipping : 735 $ Pretty Good
IF this isn't good for gaming what is this good for? i need 2 PC but one is Optional
USing for? : Gaming
OS : Win XP Pro 32-bit (i dont need more than 3.5Gb ram)
Crossfire: Maybe
SlI : I have no idea what this is, help?
Budget : 500~1000$ CAD
WARNING : May contain noob questions.
Build:
USing for? : Gaming
Crossfire: Maybe
