Hi friends ,
I am going to buy a PC in this month .
The main purposes are as following in descending order :
3d Animation in Maya & 3dsMAx , Gaming , Photoshop and some other editing , Browsing or surfing .
My budget is around $ 800 - $ 900
I am thinking of this configuration : -
(Confused with RAM and CPU)
Config :
CPU : Core i5 i750 2.66GHz @ $200 / Core i7 860 2.80Ghz @ $280
(confused b/w two)
Motherboard : Gigabyte P55 UD4P @ $140 / P55 Asus 1156 Extreme
(whichever is better ???)
Memory : Corsair 4GB DDR3 1600MHz C9 Titanium @ $115
(A bit confused with the RAM Should i buy 4gb single stick or 4gb kit (2X2gb) . Does stick improves performance or kit is necessary with i series ??)
Casing : Cooler Master Elite 334 @ $35
Cooling : Coolermaster Hyper N520 @ $50
HD : Seagate Barracuda 7200.12 1TB @ $80
Power supply :GlacialPower 650W AA @ $90
GPU : Radeon HD 4850 512 mb @ $125
(If any other better graphic cards in $120 - $150 price range plz suggest)
Total : $835 / $915
Or Should i go for i7 860 instead of 750 , as i am planning to use this PC for at least 4 years
Also i have heard that there is some problem with LGA 1156 socket boards so can anyone please give some helpful review ?
i dont want to overclock my system so should i need to buy an aftermarket cooler ?
Any other good suggetions for mobos , CPU , memory or any parts are welcome just keep in mind friends i cant exceed my budget .
Thank you all in advance !!
Config :
(confused b/w two)
Total : $835 / $915
