Hi! I am new to this and need some advice on a system that I am planning to build. I have not yet purchased components but have an intended list. I would like any advice as to whether my list would work well together or not. Thank You in advance.
The Build Is:
Lian Li PC-7FN Mid Tower Case
Thermaltake TR2 W0070RUC 430 watt power supply
Biostar TA790GXB A2+
AMD Phenom x4 920 Quad Core 2.8GHz
4GB/s DDR3-1066 MHz SDRAM
500GB/s 7200rpm SATA 3 GB/s
1 GB ATI Radeon HD 4650
DVD Rom
Windows 7 professional 64 bit
The Build Is:
DVD Rom
