Noctua NH-D14 CPU Cooler compatible with ASROCK z77 Extreme 4 Mobo?
Hi,
I'll be running an I5 3570K, OC to 4.5 ghz with the Noctua NH-D14. Just wondering if it is to big for the asrock extreme 4 mobo. I'll be using this ram: http://www.pccasegear.com/index.php?main_page=product_info&products_id=20093 A friend of mine has the same setup but just took the coolers off the ram for the noctua to fit. Is this all compatible or is there a better ram for similar price.
1 answer Last reply
More about noctua cooler compatible asrock extreme mobo
  1. http://www.noctua.at/main.php?show=compatibility_ram_gen&products_id=34#DDR3_G.Skill
    According to noctua it is not compatible as the ram comes.
    Your friend removed the ram coolers or a fan?
    You can use these:
    http://www.alientech.pt/product_info.php?products_id=14888
    Those fit according to noctua.
CPUs Cooling RAM Compatibility ASrock Overclocking
