Solved
WIll this water cooling system fit nicely in my case?
Thermaltake WATER2.0 Pro for $89 + $30 MIR @ Newegg http://www.newegg.com/Product/Prod [...] 6835106189
Seems like a nice deal. What is the Corsair equivalent to this? And will I have any troubel installing it on a 500r/300r/or 200r (Thinking of downsizing case because of limted room).
Will I see any major difference from my Hyper 212 EVO.
11 answers Last reply Best Answer
More about will water cooling system nicely case
  1. I would say that it would not be significant enough to warrant a change, it probably will produce similar results and may even be louder than the evo.
    I've been told that, ya. Just thought this might be fun to try however, I'm only willing to buy if it's a significant difference. Not looking like it so far.
  3. Not that fantastic of a cooler and I wouldn't expect much more than maybe 1-2C at 100% load on high fan speeds over the Evo you currently have.
    Is there a particular reason you are downsizing your case, but getting a bigger cooler?
  4. Best answer
    Most of those pre-made water cooling systems are rather sub-par, and seem pretty expensive for what you get. If it was your first cooler, you could probably give it a shot, but since you already have the Evo I would not bother paying more for similar performance. If you want to add performance, and do not already have it set up push-pull, add a fan. Otherwise you already have one of the best coolers at it's price range, you won't find much better value wise.
    My 500r is too big to fit where I used to keep my old pc. It's currently on the ground and in the way. But also, I just didn't like as much as I thought I would, as far as looks.
  6. Best answer selected by 123364.
  7. I get why you are going with a smaller case, but you didn't really address the large cooler other than (possibly) looks and if it would cool any better (which it isn't, but dependent upon case airflow for both).
    Oh, I just thought the water cooler would give be better results. I wanted to take advatage of the deal @ Neweeg, but I think I'll pass.
  9. Good call, I have to convince myself not to buy more newegg and amazon deals almost daily lol :P
  10. Overall considering cost and your current cooling option, you are better off, especially when you are downsizing your case, anyway.
  11. Thanks everyone!
Water Cooling Cases Thermaltake Overclocking Product
