Tom's Hardware > Forum > Home Theatre > ReplayTV > HELP-RTV Network Problems
Forum Home Theatre : ReplayTV - HELP-RTV Network Problems
Archived from groups: alt.video.ptv.replaytv (More info?)
After a power outage - both the 5080 and the 5040 are on surge protectors -
I have lost the ability to network either of these units.
In fact, if I connect the RJ45 ethernet cable(s), the units go into a
constant reboot, recording fragments of scheduled recordings.
One of the units does this even if not connected to the network. Has anyone
experienced similar issues? If so, how did you rectify the problem(s)?
Thanks in advance for any pointers.
Sponsored Links
On Mon, 2 May 2005 17:02:46 -0700, "paul diener" <pdiener1@cox.net>
That will happen if your Replays are set to "obtain an IP address
automatically" and there is no DHCP server present. That's usually in
your router. Is it working properly?
If it's set to use the network, the result is the same as above (no
DHCP server). You'd need to get that working before you reboot the
Replays.
BTW, you said ONE of the units. What does the other do?
Mark Lloyd
has a Replay 5xxx
http://notstupid.laughingsquid.com
"The idea that there is an invisible being who
created and still runs this old universe is so
childish, so obviously contrived, that it is hard to
believe anyone with even a modicum of education can
still fall for that scam."
Reply to Anonymous
There are 1069 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
