APPROXIMATE PURCHASE DATE: Tonight or Tomorrow
BUDGET RANGE: 700 - 800
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Surfing/Gaming/Movies
PARTS NOT REQUIRED: Keyboard/Mouse/Monitor/Speakers
PREFERRED WEBSITE(S) FOR PARTS: Newegg - willing to look elsewhere if there are better deals
PARTS PREFERENCES: None
OVERCLOCKING: No SLI OR CROSSFIRE: No
MONITOR RESOLUTION: Min 1440x900
Looking for a good multitasker that will last for a while and have the ability to upgrade as needed in the future
Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case - Retail - $61.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive - $54.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL - Retail - $104.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM - $104.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
COMBO $283.98
AMD Phenom II X4 925 Deneb 2.8GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 95W Quad-Core Processor - Retail
HIS H577FM1GD Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card - Retail
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.324025
COMBO $86.98
OCZ ModXStream Pro OCZ600MXSP 600W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply compatible with core i7 - Retail
LITE-ON CD/DVD Burner - Bulk Black SATA Model iHAS124-04 - OEM
Is a 600W PSU enough?
There is also this one and one for a 500W
COMBO $101.98
OCZ ModXStream Pro OCZ700MXSP 700W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC ... - Retail
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.328941
Which MB?
GIGABYTE GA-MA770T-UD3P AM3 AMD 770 ATX AMD Motherboard - Retail $74.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128392
GIGABYTE GA-770TA-UD3 AM3 AMD 770 SATA 6Gb/s USB 3.0 ATX AMD Motherboard - Retail - $94.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128419
Is there an ASUS model someone would recommend over either of these?
Thanks!
COMBO $283.98
COMBO $86.98
COMBO $101.98
Which MB?
Thanks!
