Solved
Not enough power supply output cables
Hello,in my PC power supply there is only five output cable and all of them are in use and i need additional cable because i want to customized my PC with lights...etc
i don't know if there is other solution to this problem instead of purchasing another power supply which is very costly can you please help me
5 answers Last reply Best Answer
More about power supply output cables
  1. Best answer
  2. thanks
  3. Interesting connectors. That's what you call quick connect.
  4. I use them for modifying cables all the time, have SATA versions in the drawer as well.
  5. Best answer selected by asskiller3.
Power Supplies Cable Components
