Solved
New system Build...Need some advice!!
  • New Build
  • Systems
  • Product
Last response: in Systems
February 9, 2010 6:18:35 AM
So i first just want to thank all the people who have commented on my post before!!! You have all been truly helpful and I'm grateful you took the time to help me out!!
APPROXIMATE PURCHASE DATE: FRIDAY FEB 09
BUDGET RANGE:$900
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: GAMING, VIDEO EDITING, SCHOOL WORK
PARTS NOT REQUIRED: MONITOR,OS (WINDOWS 7 64 BIT),VIDEO CARD (I HAVE THE SAPPHIRE OC 5970 THAT I WANT TO RUN), KEYBOARD, MOUSE
PREFERRED WEBSITE(S) FOR PARTS: NEWEGG.COM OR TIGERDIRECT.COM WHICHEVER IS CHEAPER
PARTS PREFERENCES: I WOULD LIKE TO USE THE HAF 932 CASE IF POSSIBLE. OTHER THAN THAT IM OPEN
OVERCLOCKING: YES
SLI OR CROSSFIRE: NO
ADDITIONAL COMMENTS: Thanks again in advance for the help and im open to any suggestions or advice you may give!!
More about : system build advice
February 9, 2010 6:43:58 AM
^ You still need OS and monitor in that budget ?
And I doubt you will be able to get an i7 920 build within that budget with the monitor and OS...
m
l
February 9, 2010 2:58:36 PM
sorry everyone i dont need the monitor or OS this is everything but that. Thanks!!
m
l
Best solution
February 9, 2010 3:07:38 PM
Changes:
Monitor: Subtract $150
CPU: i7-920 Add $89
Mobo: Asus P6X58D Premium Add $30 (above the combo)
RAM: G.Skill Pi Series 3x2 GB 1600 mhz CAS Latency 7 Add $65
Total: $964.
If that's too much, here are some changes from above:
CPU: i7-860 Subtract $9
Mobo: Asus P7P55D-E Pro Subtract $120
Total: $835.
February 9, 2010 3:16:32 PM
February 10, 2010 5:06:29 AM
Ok so i think this may be what i go with. Let me know what you think!!!
Case: HAF 922
Memory: G-Skill P.I. Series (3x2)
Mobo: ASUS P7P55D E-Pro
CPU: i7 920
Power Supply: OCZ 700w and Hard Drive: Samsung Spinpoint 500gb
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
CPU Cooler: Hyper 212 Plus
I want to OC the CPU to like 3.8 if i can and the 5970 will have enough clearance in this case correct???
m
l
February 10, 2010 5:23:27 AM
^ The i7 920 is a LGA 1366 pin CPU whereas the mobo that you have chosen is a P55, which supports only LGA 1156 CPUs...
So choose a mobo that has X58 chipset...
ASRock X58 that techmo linked, Asus P6X58D Premium that MadAdmiral linked, and the Gigabyte X58A that I linked are the X58 boards that support the 920...
Or you can choose the i7 860 route and go with that mobo and 4GB of RAM, that would offer very similar gaming performance as that i7 920 setup...
m
l
February 10, 2010 3:23:14 PM
lol thanks for the catch!! I went with the gigabyte you linked and i also was able to bundle it with the i7-920. So changing that out with the rest of the stuff from above im sitting at around 923.34!! Thanks for all the help guys!! I may be coming to you for more advice on OCing this thing if you want to help. I also plan on taking pictures so you can see all the advice you have given put into action!!
m
l
February 18, 2010 1:52:31 AM
Best answer selected by r_manic.
m
l
