I am looking to build my first PC and am in some need of some help...I want to spend under $1,000 and want the computer to perform fast and look good...I also want to make sure that what I am looking at will all work together well!
Motherboard: Intel BOXDH55HC LGA 1156 Intel H55 HDMI ATX Intel Motherboard
Processor: Intel Core i3-530 Clarkdale 2.93GHz 4MB L3 Cache LGA 1156 73W Dual-Core Desktop Processor
Memory: CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMX4GX3M2A1600C9
Graphic Card: XFX HD-577A-ZNFC Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
Power Supply: CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
Disc Drive: ITE-ON Black 24X DVD R 8X DVD RW 8X DVD R DL 22X DVD-R 6X DVD-RW SATA CD/DVD Burner
Hard Drive: Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
Case: NZXT M59 - 001BK Black Steel ATX Mid Tower Computer Case
Please let me know if this would all go together properly and work well or of any suggestions you have. Thanks!
