Power Supply with 12 x 4-pin molex peripheral connectors
I need a power supply with 12 4-pin molex connectors for a norco 4220 case (powers hot swap drive bays) with rated for maybe 500 watts of output.
I realize that 20 hdd's will take a bunch of power to spin up, however the controller I am using supports stagged spin-up.
Are there any that are recommended?
5 answers Last reply
More about power supply molex peripheral connectors
  1. None that i know of... but use splitters on existing molex or adaptors with sata cables??
  2. A Corsair 550VX has 8 molex connectors and with its 41 amp 12 volt rail, has plenty of power.
  3. +1 what jsc said.
    The Corsair VX550 is a heavy duty power supply that is table and reliable.
    You could use one splitter on 4 of the 8 molex connectors:
    http://www.google.com/products?hl=en&q=4+pin+molex+splitter&um=1&ie=UTF-8&ei=4xbLS-mqPJCisgOAkbnBAw&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CBoQrQQwAA
    Here's a quick connect version that should work quite well since you can select where you want to added the connector along the length of the power cable:
    http://www.frozencpu.com/products/7616/ele-345/Standard_4_Pin_Low_Profile_Easy_Install_Connector_w_Cover.html?tl=g51c387
    I'm surprised you are still using 4 pin molex connectors. Must be older hard drives. Just out of curiosity what are you doing with 12 drives?
    Corsair and Seasonic are two brands that have a reputation for high quality power supplies that consistently earn high marks in technical reviews. They are reliable, stable, and come with a 5 year warranty. Some of the newer models come with a 7 year warranty.
  4. Thanks Yall
Power Supplies Peripherals Components Product
