Solved
Highest CFM fan help
November 4, 2012 5:44:59 AM
Hi all,
I am trying to find the highest CFM fan which I can get from https://www.umart.com.au/newindex2.phtml?bid=2 which is a 120mm or 140 mm.
The one I am looking at CFM wise would be a BitFenix Spectre Pro PWM 140mm fan. It rates at 122 CFM it is the best fan I can find on the web site.
Link to fan I am currently looking at getting
https://www.umart.com.au/pro/products_listnew.phtml?id=...
Manufactures website:
http://www.bitfenix.com/global/en/products/accessories/...
Any help would be nice, thanks.
More about : highest cfm fan
a c 150 K Overclocking
November 4, 2012 5:55:00 AM
What is this for?
m
l
November 4, 2012 6:59:19 AM
Sorry I forgot to mention that.
It will be top exhaust for a 500R
^ Abbadon don't do stupid things like that around here.
m
l
November 4, 2012 7:24:27 AM
stupid like what? answer the question? post an expensive piece? a powerful piece? take time to google through severate website for answers? filter through results until i find one that is specific to your country? i'm lost at what i could have done to ignite your ire , unless a moderator cares to share
m
l
November 4, 2012 12:12:47 PM
My original post says it must be from umart not just anywhere in Australia.
m
l
Best solution
a c 239 K Overclocking
November 4, 2012 12:19:20 PM
zcoot said:
Hi all,
https://www.umart.com.au/pro/products_listnew.phtml?id=10&id2=227&bid=2&sid=73396
Check out the cooling fan roundup in my sig, it will help you in a cfm fan comparison.
Sometimes the fan claims are not the actual performance.
November 4, 2012 12:25:30 PM
Best answer selected by zcoot.
m
l
November 4, 2012 1:46:18 PM
You have to keep in mind high CFM equals high noise levels, that's why most of us use fan controllers so we can crank it up when gaming, and turn it down while surfing the net and such as that.
Thanks for the B/A! :)
m
l
November 5, 2012 10:22:57 PM
I understand the controller thing but the fan I wa looking at is quiter at its higher CFM. I am planning on using the fan headers on my Z77 Extreme 4 when I upgrade and some software to control them.
Also you deserved the B/A
m
l
