Sign-in / Sign-up
Closed
Problem with storage drive
  • DVD Drives
  • CD-Rom
  • Storage
Last response: in Storage
February 15, 2012 5:40:48 AM
My Laptop with OS Vista, does not read/burn\ CDs while it reads DVDs.?
Like it will not play a Video or Audio CD, but will play a DVD. After inserting a CD, if I open My computer in the CD drive it says, Insert CD.Please guide me what to do.
More about : problem storage drive
Best solution
a c 80 G Storage
February 15, 2012 11:20:53 AM
CD/DVD lasers are on separate heads. You could try running one of those cds through that is supposed to clean the laser, but I have never seen those work very well. If it's under warranty contact the manufacture. If it's not you may want to look at a small usb cd/dvd drive as that will likely be much less expensive then trying to find a replacement one to match your laptop. Particularly if you don't actually use the drive very often a usb drive would work well.
February 22, 2012 9:59:25 AM
Best answer selected by vajith2000.
Score
February 22, 2012 10:01:52 AM
Thanks a lot buddie, it worked
Score
a c 475 G Storage
February 24, 2012 11:44:35 PM
This topic has been closed by Area51reopened
Score
