G
Guest
Guest
Archived from groups: alt.games.thief-dark-project (More info?)
Just upgraded my graphics card from FX5200 to FX5900. Desktop
looks OK, got full range of resolutions up to 1280 x 1024 32-bit
color. My Thief 2 mission is 'running' OK, in fact smoother,
better frame rate BUT color or texture or something has gone
haywire. Super high contrast with totally bright colors and very
BLACK shadows. Distance is mostly all black and springs into
bright as I approach like a light automatically going on as you
approach. And I get screen res not supported message in-game on
any res I set in-game. Just persisted a little longer and it
finally dropped out to the desktop. Now the game won't run at
all and gives 'failed to set video mode'.
The only other 3D game I have is Prince of Persia and this won't
run either. It gives 'game ended unexpectedly - see readme file
for tech support'. Tried re-installing this game but no
different. So not confident about re-installing Thief.
Just downloaded the latest drivers for the card but no
difference.
The FX5900 was sold as for Win9X. I installed it on Win98 1st
edition. But here and there in the manual it refers to Win98 SE
so it is not clear whether it fully supports 1st Edition. As
said, the card works fine on the desktop. There were no errors
when installing it.
Any suggestions?
difference.
when installing it.
Any suggestions?
