Tom's Hardware > Forum > Home Theatre > ReplayTV > Puzzling Input problem with upgraded 5040
Forum Home Theatre : ReplayTV - Puzzling Input problem with upgraded 5040
Archived from groups: alt.video.ptv.replaytv (More info?)
I own two 5040 which, when the one year warranty expired i have just
upgraded to 300gb using RTVPatch.
This was about 4/ days ago. The upgrade went fine, infact even the
shows transfered over. 24 hours ago, however, one of the two units
suddenly stopped showing live tv: Everything else worked fine (the
recorded shows where normal, other functions where normal, the network
connection (internal and external) was fine, but it simply refused to
acknowledge the digital cable signal through Input1 and Input2.
I ensured that the cable box worked, i re-did the setup, nothing. I
then put back in the old 40GB disk and everything went back to normal.
This puzzles me as i cannot see how the software onthe HD could become
corrupted in such a definite "function" I would have thought it would
have been all or nothing...
Anyhow, tonight i will repeat the full rtvpatch procedure and I am
pretty confident that it will work, but has anyone else come across
such a problem?
Other question: before doing the image transfer I backed up the 500MB
file on the PC. Can (and how) do i restore that on the 300GB disk? and
can i do it without overwriting the existing shows?
Sponsored Links
Did you low-level format the 300GB HD before you ran the patch?
Also verify that the system that you used to patch the drives saw the whole
300GB.
"Coppernob" <alexnorton@despammed.com> wrote in message
news:u8cp81hvj0b5linofhc80a614g8lipuhs2@4ax.com...
> such a problem?
Reply to Anonymous
On Thu, 19 May 2005 16:14:04 GMT, "Joseph Wind"
No, straight from the box. Do you suggest i do that for tonight's
re-image? If so i presume the Segate utility disk will allow me to do
the "low-level" format?
>300GB.
Yes, it saw the space correctly
Reply to Anonymous
If you do a low-level format on a 300 GB drive, expect to give up your
computer for about 2 days (it took me over a day with a 200 GB drive).
The efficacy of a low-level format is open to debate. I have read
several posts indicating that it is not necessary and I would be surprised
if it is the cause of your live video problem (possible, but very, very
unlikely).
The documentation for RTVPatch warns that transferring shows can cause
problems; it is possible that, if you re-install to the drive without
copying the shows, you will not have the problem.
Jeff
NOTE: Remove underscores from my e-mail address to reply personally.
Reply to Anonymous
On Thu, 19 May 2005 13:03:39 -0500, Jeff Lindstrom
But the I will have marital problems!!! :-))
I wish it was possible to move the shows onto my DVArchive HD and then
send them back to the replay....
Reply to Anonymous
>unlikely).
Low-level formatting is actually necessary, but that's what's done at
the factory. There's no need to do it agan. You can't anyway (about
98% of the time you hear "low level format", that's not what it is).
Mark Lloyd
has a Replay 5xxx
http://notstupid.laughingsquid.com
"The idea that there is an invisible being who
created and still runs this old universe is so
childish, so obviously contrived, that it is hard to
believe anyone with even a modicum of education can
still fall for that scam."
Reply to Anonymous
In article <m3hp81pvt4v1q4eupoc0v3dtkqjt1pbuq3@4ax.com>,
Possibly. You're looking to map out bad sectors.
I used SpinRite to do it on my two drives, and they've been fine since
September. Took about 24 hours each.
Reply to Anonymous
On Thu, 19 May 2005 15:45:32 -0400, "Elmo P. Shagnasty"
So you are saying that a HD straight out of the box is shipped with
Bad Sectors?
Reply to Anonymous
All hard disks have "bad" sectors at some point. Sometimes good sectors are
incorrectly marked "bad," and "bad" sectors are incorrectly marked "good."
This is one reason why a program such as SpinRite can be useful. Most
times, however, you'll never need it, as often a simple "chkdsk /f" from
your PC's OS will suffice. (The /f switches "fixes" problems.) Depending
on your OS, you may get a warning that chkdsk won't start till you restart
the computer. This is normal.
Regards,
Margaret
news:9gvp815222sdketsbqjdsod9k4hm9hbkhd@4ax.com...
> Bad Sectors?
Reply to Anonymous
That's part of a low level format, and already done when you buy a HD.
You don't need to do it on modern hard drives.
That would be more meaningful if it included the condition of the
drives BEFORE running SpinRite. As it is, it says close to nothing.
Mark Lloyd
has a Replay 5xxx
Reply to Anonymous
On Thu, 19 May 2005 13:59:32 -0700, Coppernob
>Bad Sectors?
Physically, every hard drive will have bad sectors, which need to
remapped. That is part of rhe low level formatting that drive
manufacturers have been doing for 10 years or so. What you get will
appear to be a perfect drive (no bad sectors), and can be used as
such.
Mark Lloyd
has a Replay 5xxx
Reply to Anonymous
Er, not exactly true. Why SpinRite takes so long to run is that it does
multiple writes to each sector to determine whether or not each is good or
bad. A sector previously marked "bad" might test "good" and be reassigned
as such, just as a previously marked "good" sector will be marked "bad" if
it fails the write test(s).
I won't be sticking around to debate this or any other issue, not because I
post and run.... Tomorrow morning I go into the hospital at 6:00am for
surgery. Hopefully I will emerge at some point to resume using and talking
about RTVs. ;-)
Regards,
Margaret
"Mark Lloyd" <mlloyd@5xxxmail.com5xxx> wrote in message
news:lq2q81drle3d9dk5e0k9os4iskvq4h72d9@4ax.com...
Reply to Anonymous
> such a problem?
It is doubtful redoing RTVPatch will accomplish anything. What do you
mean by "refused to acknowledge". Do you mean selecting something from
the guide and the Replay would not change the channel on the box and
switch the input??? Or is it tuning the box and not switching?
Go into setup and define Input 1 and 2 as nothing. This will make the
unit reboot and redo the channel guide. Clear the channel guide TWICE
and then redefine the inputs. Your old shows will remain, but you may
have to "save till I delete" all of the shows and recreate the record
channels that made them.
Reply to Anonymous
If it's any help, I have no problems playing shows archived on my
computer through my RTV. The computer storing the files is only an 850MHz
PIII.
Jeff
Reply to Anonymous
On 5/19/05 7:31 PM, in article d6jb0p01i79@news4.newsguy.com, "Margaret
> about RTVs. ;-)
> Regards,
> Margaret
Good luck and God bless.
_______________________________________________________________________________
Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com
<><><><><><><> The Worlds Uncensored News Source <><><><><><><><>
Reply to Anonymous
The IR would work correctly, simply the scrren would say that there
was no video signal.
In actual fact the RTVPatch that i did last night set everything back
to normal. I hope it stays that way!
Reply to Anonymous
Question: How many software engineers does it take to change a light bulb?
Answer: None, it's a hardware problem
You have a blown switching transistor on the mother board
Just don't ask me which one (or logic gate)
John F Davis, in Delightful Detroit. WA8YXM(at)arrl(dot)net
"Nothing adds excitement like something that is none of your business"
Diabetic? http://community.compuserve.com/diabetes
Reply to Anonymous
> Bad Sectors?
Most of them yes, I'd say there is a one in a million (or larger) chance
your brand new drive is error free, but most every drive I've seen has a
sticker on it listing bad sectors.. Low Level Format (and in some cases
programs used later, even after data has been added to the drive) will
scan for them and map them out so your computer never uses them
In fact FORMAT (not low level but the regular FORMAT) command is
SUPPOSED to do this.... I'm not sure it does, but it's supposed to
Reply to Anonymous
On Fri, 20 May 2005 20:31:02 GMT, John in Detroit
That's what I thought. Must be a hardware problem, which would be
logical as the warranty and expired the week before... :-))
But i when a put in the original disk it all worked ok. swiitched the
new HD, nothing so last night i re-patched the new HD and everything
works fine.
Reply to Anonymous
On Fri, 20 May 2005 20:34:03 GMT, John in Detroit
>> Bad Sectors?
My first HD had such a sticher, but that was over 14 years ago. I've
bought a lot of drives since and not one has had such a sticker.
Both work if you have a VERY OLD drive.
Mark Lloyd
has a Replay 5xxx
Reply to Anonymous
LOL, I still have a Seagate ST-251 RLL HD sitting on a shelf. I wonder if
it still works.
news:uqbt81p023hbelkpqpnom925dc4c0dbv33@4ax.com...
Reply to Anonymous
Interesting... I can still think of a few hardware issues that might be
fixed by doing the drive swap
> works fine.
Reply to Anonymous
Now that you mention it I don't recall seeing it ON the last drive I
bought either (Problem is there are so many sectors now that the sticker
gets kind of large) But I do recall it being IN the drive (The
information included on the drive when you first buy it includs a map of
bad sectors) It's just where you used to be ablue to read them with a
proper lamp and glasses... now days you need a computer and software,
And truthfully.. i don't know what software
Reply to Anonymous
On Sat, 21 May 2005 07:11:49 GMT, "Joseph Wind"
>it still works.
My first drive (Seagate 30MB RLL) was working in December 2002 when I
sold it.
Mark Lloyd
has a Replay 5xxx
Reply to Anonymous
There are 1102 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
