G
Guest
Guest
Hello,
I'm keen to finally retire my P4 PC. I want to get a whole new system that I can use for recording, multi-tracking, mixing and mastering. As well as decent support for stacking various effects and VST instruments. Music production is my main concern but I would also like to use it for various art software (photoshop, illustrator, corel painter, etc) as well as an average video card that can support duel monitors and some WOW playtime (after the graphics update I stopped playing, nothing fancy, something good enough to play it comfortably)
My goal is to keep my new rig at around the 800 dollar mark.
So far the recording has worked ok for me on my P4, but due to being over 5 years old, latency issues, and extreme choppyness playing a song in Fruity Loops with several instruments, its done my head in enough to finally update my system.
Now I have an idea of what I need, but I do not know certain details about some hardware. (what they are compatible with, are they upgradeable etc.)
Which is why I have come here.
The PC needs to be able to run Pro Tools with few plugins/effects/VSTs. Of course 64bit is a given. I don't need anything extravagant.
Being a singer songwriter I would like to be able to throw in some synth pianos, strings, bass, drums and a few effects, with some CPU headroom for extras if I decide to do so later down the track. At the moment I am running Sonar and Adobe Audition.
So far I have:
Monitor
Keyboard
Mouse
DVD Burner
Soundcard(will have in a few days) http://www.newegg.com/Product/Product.aspx?Item=N82E16829121011&Tpk=delta%201010lt
I really want to get myself an i7, because that is the advice I have been given already for what I want to do but I believe it is way out of my price range.(well I suppose nothing is on a long enough time frame, but I want this setup within two months) Does AMD have anything comparable?
So yeah, basically all I need is:
Motherboard
CPU
GPU
Case
PSU
RAM(8gb in the future but can live with 4 for now)
And a massive hard drive.
If anyone can make sense of this and help me out it would be very appreciated.
So far I have:
Monitor
Keyboard
Mouse
DVD Burner
Motherboard
CPU
GPU
Case
PSU
