GIGABYTE GA-890GPA-UD3H AM3 AMD 890GX HDMI SATA 6Gb/s USB 3.0 ATX AMD Motherboard-$134.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128435
Cheaper and better case and psu combo imo.you don't need a 750w psu.-$149.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.492974
MOBO/CPU combo-Now: $280.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.502081
Better faster ram-Model F3-12800CL7D-4GBRM-$95.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303
Everything for $526.95 including better ram and case.
Yours $582.95 for inferior ram and a psu you won't need the XFX 650W is modular and more then enough power (btw i own a HX750)
As far as the case goes it's a Lian-Li with 4 fans and a bottom mount psu compared to an XCLIO with 2 fans and crappy top mount psu location but whatever that's your choice.
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007583%2050001375%20600006302&IsNodeId=1&bop=And&CompareItemList=7%7C11-103-010%5E11-103-010-TS%2C11-112-239%5E11-112-239-TS
