Msi gtx 660 ti power addition twin frozer 2 waterblock
Hello everybody :hello: , I was looking for a waterblock for the msi gtx 660 ti power addition twin frozer 2, and i couldn't find any. I am brand new for watercooling, so i would really love to have a full block, and not a gpu cooler with heatsinks.
All suggestions are welcome :pt1cable:
14 answers Last reply
More about power addition twin frozer waterblock
  1. Hello-
    In most cases the TF2 bored are not designed to be changed to water cooling- the reason behind this is that Most water cooling blocks are designed only for reference cards(original Nvida die). MSI changes a lot of composite around to incorporate there cooler. + this is a Ti so it already changes things a bit as I cant even find a water cooling set up for just the Ti.
    As a back up plan the go have generic water cooling blocks you might be able to make something your self.
    I found a few pics that show the heat spreader on the gpu core is gone if there was any doubt as to reference or not.
  2. thequn said:
    hello- In most cases the TF2 bored are not able to be changed to water cooling-the reason behind this is because Most water cooling blocks are designed only for reference cards(original Nvida die). MSI changes a lot of composite around to incorporate there cooler. + this is a Ti so it already changes things a bit as i cant even find a water cooling set up for just the Ti.
    i found a few pics that show the heat spreader on the gpu core is gone
    darn, problem is I don't know how to watercool without a full face block. May you please post the pictures?
  3. the koolance GPU-200 Water Block might work for you i have seen people use them for playstations
  4. unfortunately its like water cooling your north bridge not something a first timer would do.
    May I ask why you want to water cool your 660 ti? its a beautifully designed card.
    I might get banned for this but here s list for the 660ti on a closes loop.
    http://www.bjorn3d.com/2012/09/arctic-accelero-hybrid/ a little pricy at the bottom they show grids for your card.
    I looked at it, and it is a plastic fan that the extended part covers a full premade watercooler
  6. You can do a mod for it.....
    http://www.overclock.net/t/1203528/official-nvidia-gpu-mod-club-aka-the-mod
    Or you can go with a universal block and memory+vrm sinks.
    http://img16.imageshack.us/img16/353/img36731.jpg
    problem is thati can't afford a second watercooling cycle, and if I attach a cpu waterblock, then i would need small heat sinks, and then it becomes too risky
  8. Closed loops for the mod are around 30-40 bucks.
    You wouldn't be attaching a cpu block, it's a universal gpu waterblock. It's completely different. As for sinks, those can be easily made or bought for about $6.
  9. I dont see the point of watercooling msi's versoin of the 660ti. it runs soo cool already. unless its noise that your worried about, which i still dont see how the watercooling loop would help out.
    I would like to overclock, but not to the extreme
  11. Then stick with the TF cooler. It can handle extreme oc's.
    oh ok, but how loud is it?
  13. oh dear and here i assumed you had one- they are much better then a stock fan noise- ill get this real list. give me a few...
    ok got its 38 dBA, at full load so about 5 over the sound of a D5 pump.
    Haha ya, I guess I will buy one and leave the stock cooler
Graphics Cards Gtx Power Overclocking MSI-Microstar
