G
Guest
Guest
Hello,HELLO I BUILT A NEW COMPUTER USE DP45SG MOTHER BOARD WITH Q9650 PROCESSOR 2 GIG CRUCIAL MEMMORY 1066/1333 ANETEC 700 POWER SUPPLY THERMALTAKE A90 CASE NVIDA 9500 GT 1 GIG VIDEO SEAGATE SATA HARD DRIVE 500 GIG. I HAD THE SAME PROBLEM WITH THE COMPUTER TIMING OUT FOR THERMAL TRIP, FOUND OUT THE PROBLEM WAS THE CPU FAN HAD PULLED LOOSE ON ONE SIDE AND IT CAUSED THE SYSTEM TO REBOOT EVERY TIME IT STARTED UP. SINCE THEN THE COMPUTER HAS BEEN RUNNING WONDERFULL. MY ADVICE DONT BLAME THE MOTHERBOARD IF WE DONT CHECK FOR THE LITTLE MISTAKES WE MAKE. ALWAYS CHECK FOR COMPATIBLITIES WITH RAM SO ON.
