Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > [Solved] [New system build] Quiet low-power HTPC
Forum Systems : New Build [Solved] [New system build] Quiet low-power HTPC
Best answer from Dougie Fresh.
APPROXIMATE PURCHASE DATE: ASAP
BUDGET RANGE: whatever it takes but as cheap as possible
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: recording tv shows through tuner card, watching movies, storing my media, serving files on home network
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers
PREFERRED WEBSITE(S) FOR PARTS: ebuyer.com
COUNTRY OF ORIGIN: UK
PARTS PREFERENCES: Intel i5 on microATX mobo
OVERCLOCKING: no
SLI OR CROSSFIRE: no
MONITOR RESOLUTION: No monitor needed - will connect to TV
ADDITIONAL COMMENTS: I imagine it will be on most of the time so I would like it to be low power. It will be in the living room so I would like it to be quiet.
OS: Ubuntu/mythbuntu (I have Ubuntu on my laptop and am happy with it)
PARTS:
Intel Core i5 661 3.33GHz Socket 1156 - £153.73
http://www.ebuyer.com/product/185942
What HSF do I need/want for this CPU? The quieter the better.
Intel TOM COVE DH55TC H55 Socket 1156 VGA - £74.61
http://www.ebuyer.com/product/185943
Antec NSK1300 MATX Cube Case Black/Silver - With 300W PSU - £60.74
http://www.ebuyer.com/product/112650
Western Digital WD15EARS 1.5TB Hard Drive SATAII 5400rpm 64MB Cache - £77.99
http://www.ebuyer.com/product/182437
Corsair 4gb (2x2gb) Ddr3 1333mhz Xms3 - £96.17
http://www.ebuyer.com/product/166463
LG CH08LS10 Super Multi Blu-Ray Reader & DVD±RW - £80.28
http://www.ebuyer.com/product/177383
Hauppauge 289 WinTV Nova-T 500 Dual digital DVB-T PCI TV Tuner - £70.55
http://www.saverstore.com/product/ [...] -TV-Tuner-
Total cost is under £650
QUESTIONS:
- Is a Core i5/mobo combination a reasonable choice for the task and is it low power?
- What sort of power can I expect the system to draw when idle?
- Am I right to go for onboard GPU? As far as I can work out this should lower power consumption significantly and should still be powerful enough for movie watching. Also could be upgraded later.
- Is the Hauppage Nova T-500 a suitable PCI card? I want a dual card at minimum. I just have an aerial at home, no satellite.
- There are several options for HTPC software. XBMC. mythtv. Any recommendations?
- If I wanted to get some redundancy in the storage what would be the most cost effective upgrade? Some sort of RAID solution?
- For power reasons I guess I am better with just one HDD though. Is this true?
Thanks for reading this and any advice!
John.
Reply to JohnReid
Best answer
The i5-661 doesn't look like a great value compared to the other i3/i5 processors for what you want to do. You could go with i5-650 or i3-530 and still be able to do what you want to do with no problems and save quite a bit of money. Sure, the i5-661 is faster but for what you want to do you don't need faster. The others are already fast enough. For instance, I ran XBMC with Windows 7 using a AMD Athlon X2 2.6Ghz processor and the on-board 780G (ATI HD3200) graphics without a hitch. Even the i3-530 blows that setup out of the water.
I have the Antec NSK-1380, which is the newer (but still been around a while) version of the NSK-1300 you have above. I think it's a big PITA. It's also really bad for heat dissipation, especially once you stick a card into it. It the drawback to a cube case where the PSU and the ODD overhang the motherboard. And, in that case, the only fan is the PSU fan. The NSK-1380 comes with a slot blower, not sure if the NSK-1300 does, but once you put a card in it I think it would become moot.
And, forget fitting 2 drives in that case with a card. You lose one of the HDD "bays" to the card and you've already lost the other one to all the wires from the PSU to the front of the motherboard. It's really one HDD max in that case despite it having 3 spots.
If you have the room, something like this http://www.ebuyer.com/product/130945 would be a better choice with more room for HDDs and tuner cards.
Reply to Dougie Fresh
The thing with cube cases is the clearance for the cpu cooler. Generally, the stock cooler will fit just fine. The BIOS of a modern mobo will let you control fan speed. If in doubt, check the mobo manual.
As for quiet cooling, it's the dB(A) that determines the noise. I don't think you can hear 20 dB(A). 25-30, most def. That's what you look for in a quiet fan.
http://www.ebuyer.com/product/173868
IMO, green is a cash grab. Everything that was old is new again, but costs more cuz of green. Also, every modern cpu has a technology to save electricity. Be it Intel or AMD. For Intel, it's Enhanced Intel SpeedStep® Technology. It's on by default. When the cpu idles, it throttles down the clock speed and uses less wattage.
Quote :
Enhanced Intel SpeedStep® Technology is an advanced means of enabling very high performance while also meeting the power-conservation needs of mobile systems. Conventional Intel SpeedStep Technology switches both voltage and frequency in tandem between high and low levels in response to processor load.
http://ark.intel.com/Product.aspx?id=43553
Reply to p55ibexpeak
I think looking for a 'green' CPU is important in an always on HTPC. Your electric cost per year is about 9 * elec. price($/kwh) * watts, so for an average US price of 10c per kwh, a 50 watt saving would save you about $45 per year. My HTPC is eating about 150W, so I'm looking for ways to trim the fat. Would love to use an atom or similar board but not sure if will cut it.
Reply to smumey
The new Clarkdale processors are very efficient compared to other HTPC solutions out there right now, even against 45W TDP Athlon "e" CPUs
http://www.tomshardware.com/review [...] 16-13.html
Message edited by Dougie Fresh on 02-12-2010 at 06:35:05 AM
I would go with a i3-530 CPU for this build. It is cheaper than the i5-661 CPU and consumes slightly less power. Encoding will be slightly slower, but not by too much.
See following Anandtech review which compare both the mentioned CPUs:
http://www.anandtech.com/cpuchipse [...] i=3724&p=2
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
Thanks all above for much useful info.
From the review, it seems to me the i3-530 is not more power efficient at idle which will be the default state of the system. I'm torn between the 2 to be honest, the £50 saving might tip me in favour of the i3-530.
Reply to JohnReid
That sounds like good advice to me, I'll go for this case.
Reply to JohnReid
I would also go for an i3-530. The dual-core i5s are rather over-priced IMO.
Also, I would look at a case more like the one Dougie suggested; it fits better in an HTPC environment (:
Last thing, look for a faster drive, like the Samsung Spinpoint F3 or Seagate 7200.12. Both also consume less energy.
http://www.ebuyer.com/product/173804
Reply to blackjellognomes
I looked at this
http://www.tomshardware.com/review [...] 331-8.html
and decided if the system was going to be idling most of the time then the power requirement at idle was the most important metric. So I'm tempted by the WD15EADS
http://www.ebuyer.com/product/160649
which seems to have the lowest idle power consumption for a 1.5TB drive with reasonable other characteristics (low noise, speed, etc...)
I think when I went to ebuyer, I got it confused with the one I listed in the original post WD15EARS. Thanks for drawing my attention to that!
Reply to JohnReid
Ok thanks for all the advice and I think its helped me decide on the following components. I'm still a bit confused about cooling.:
Antec NSK 2480 MATX Desktop Case Black & Silver - With 380W EarthWatts PSU
Intel TOM COVE DH55TC H55 Socket 1156 VGA DVI HDMI Out 8 Channel Audio MATX Motherboard
intel Core i3 530 2.93GHz Socket 1156 4MB L3 Retail Box Processor
http://www.ebuyer.com/product/185937
Corsair 4gb (2x2gb) Ddr3 1333mhz Xms3 Memory Kit Cl9 (9-9-9-24)
or perhaps I could go for this at a saving of £17 and no heatsinks stuck on either
Crucial 4GB (2x2GB) DDR3 1333MHz/PC3-10600 Memory Kit CL9 1.5V
http://www.ebuyer.com/product/166995
Western Digital 1.5TB Hard Drive SATAII 7200rpm 32MB Cache - OEM
Sony AD-7240S 24x DVD±RW DL & RAM Internal SATA Black Bare Drive - OEM
http://www.ebuyer.com/product/164449
I couldn't find a silver DVD player and I decided I don't need blu-ray yet so I'll live for the time being with a black player in a silver case. I couldn't find anywhere comparing the noise levels of the DVD players.
Some PCI TV tuner card TBD
It might be my ignorance here but do I really need a £45 fan? Is there anything more reasonably priced I could buy?
Scythe SCZP-2000 ZIPANG 2 Socket 478/775/754/939/940/AM2/AM3/1156/1366 with 140mm Fan Heatpipe Processor Cooler
So at the moment that all adds up to about £500 + the TV tuner card. Any feedback still appreciated but I feel like I'm about ready to order.
I also noticed danobar's very similar thread that was interesting to read
http://www.tomshardware.co.uk/foru [...] -list-help
Thanks again!
John.
Reply to JohnReid
There are 1476 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
1400-1800 range, first build, need feedback
By Hopz, 7 hours ago:
I would keep the 750W for future upgrades and possible SLI in the future. Will save you...
Best offers
Top experts
