S samthetuffguy Distinguished Sep 21, 2010 1 0 18,510 Sep 21, 2010 #1 am looking for a budget motherboard with ddr2 support and PICe 2.0 bus slot with core2duo processor support
Emerald Titan Aug 28, 2005 15,927 10 70,865 Sep 21, 2010 #2 would this one work http://www.newegg.com/Product/Product.aspx?Item=N82E16813128388 Upvote 0 Downvote
jsc Champion Jul 14, 2004 16,893 6 52,960 Sep 21, 2010 #3 Ah, my favorite Core2 budget board. Just what I was going to suggest. I have two. It's a competent overclocker if you select a CPU with an FSB of 200 or 266 MHz. Even if this is the Asus sub-group. Upvote 0 Downvote
Maziar Champion Jul 20, 2007 21,707 1 52,960 Sep 21, 2010 #4 This is also a great choice http://www.newegg.com/Product/Product.aspx?Item=N82E16813131377 Upvote 0 Downvote
