I need some help determining what hardware and the configuration on my home network.
Hardware Definates
Getting a Dlink DGL-4100 Wired Gig Router
Have Netgear WGR614 Wirless G router
Linksys Cable Modem
Need to connect connect 1 PC, 1 work laptop with VPN security, 1 Ooma Telo, 1 PS3, and 2 laptops wirlessly.
I have a connection box in my closet that all the cable and cat5 wires throughout the house run to. There I would like to connect my Modem and the DGL-4100 router. In the router ports I would plug the wall lines for 3 different jacks.
In one room, I have a 2x2 jack where I would like to connect the PS3 to one and then the Netgear wireless router and set it up as an access point only.
In the oner room I would like to connect a swtich from the wall fack that feeds into a Ooma Telo, Work laptop with VPN security, and another PC that get little to now us.
Can all that be done without any issues or really major configuration? I am concerned that the devices on the switch may not access properly. I have very little clue how switches work and just want to make sure that there are no connectivity issues with the Ooma and work laptop that will need to be running at the same time.
I would appreciate any idea, feedback or concerns.
Thank you.
Hardware Definates
Linksys Cable Modem
Thank you.
