I've been trying to understand an error for weeks now and I am at a loss to know what is wrong.
Here's what happens: After I download ~1GB of data, using ReGet Deluxe ver 4.1a with six connections (on XP home SP3), I loose all TCPIP connectivity until I reboot.
The failure begins when ReGet reports the following error:
Error #80072747(An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.) in CRgHttpSession::ConnectHttp()
If I try > IPCONFIG /all
everything looks fine.
But if I ping my machine (192,168.0.100) I get:
Ping request could not find host 192,168.0.100.
And if I > ping 172.0.0.1
I get a timeout!
Pinging 172.0.0.1 with 32 bytes of data:
Request timed out.... (x4)
Ping statistics for 172.0.0.1:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Now the REALLY wierd thing is that ping successfully resolves and connects to "localhost"
>ping localhost
Pinging 503GR [127.0.0.1] with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time<1ms TTL=128 (x4)
Ping statistics for 127.0.0.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds: Minimum = 0ms, Maximum = 0ms, Average = 0ms
And it also works when I use my machine's network name (503GR):
>ping 503GR
Pinging 503GR [192.168.0.100] with 32 bytes of data:
Reply from 192.168.0.100: bytes=32 time<1ms TTL=128
Ping statistics for 192.168.0.100:
But remember, Ping could not find host 192,168.0.100 by it's IP address!
One new clue...
With the most recent error, I also got an event log entry that I hadn't seen before:
Event Type: Error
Event Source: Srv
Event ID: 2019
Description:
The server was unable to allocate from the system nonpaged pool because the pool was empty.
Does anyone have an idea what is going on? I've been tracking memory, port allocations... nothing looks odd before OR after the failure. (other than Firefox consistently leaves an orphaned instance running that I discover when I reboot).
I don't know what to do, other than reinstall the OS.
Thanks in advance.
--damien
