This may seem like a basic question, but I am having some trouble mounting my 360mm rads to my case with my fans. The fans and openings in my case are 120mm. I have room in front of my case for 3 360mm rads. Each fan, a Noiseblocker PL-2 fan, comes with mounting screws and washers. However, they will not fit properly into my Hardware Labs SR-1 360 rads. I am forced to use the screws that came with the rad to mount the fans to them. But, there are some problems with this. First, each SR-1 rad only comes with 3 sets of screws. To mount 3 fans to the rad that would work, but there are none left to mount the rad to my case from the other side. Second, the Noiseblockers PL-2 fans come with rubber screw anti-vibration plugs for each hole and a rubber piece that goes around the edge of the fan you place on the side that makes contact with the case/part. If I use those rubber pieces, the screws do not fit properly through them as they are designed for the size of the thinner screw that comes with the fan. The rad screws that comes with them will work fine without the rubber pieces in place. Will that hurt anything to leave off if I must? Third, I see no way to mount fans on both sides for push/pull plus mount them to my case, if I want to in the future (right now just one set of fans).
I would like some feedback from those that have mounted 3 fans to a 360 rad and then mounted the rad in the case. Do I need to buy more screws since it only has 3 sets? If so, what size and where can I find them? Any other advice or tips for mounting the fans and rad would be nice.
Thanks.
Thanks.
