I need a expert with Aquacomputer and Aquaero 5 and its various interconnected stuff.... because I don't read German
Anyways, I got everything in my looped hooked up just fine with the Aquaero 5 XT. The only issue I'm having is with the Aquacomputer G1/4 Flow Meter Sensor Block USB Version:
First I connected the USB to the motherboard and the 3-pin cable it came with from the 4-pin on the flow meter to the 3-pin flow head on the Aquaero 5 XT...nothing. I then got the special 3-pin flow cable...the connector on one end is way too large for either the flow meter or the Aquaero. So then I got the 4-pin Aquabus cable and connected it to the Aquabus 1 then Aquabus 2 heads on the Aquaero 5. That actually got something.
On the Aquasuite 2012 software, I selected the options for Highflow USB flow meter under the MPS devices. It will not allow me to do calibration and I can't get anything better than 1 gallon/minute. I have the Swiftech Apogee II which at max output should do about 4.75 gallons/minute.
Can anyone please explain what I'm doing wrong and how I should be doing it right? Let me know if you need any other details. I really hope its not a bad flow meter...because I really would like to RMA this thing back to Germany.
Thanks!
Thanks!
