Build Components:
1 x EK 360 rad (120 mm x 59mm x 360 mm)
1 x XSPC x20 750 pump / res combo
1 x aquacomputer high flow sensor
2 x phobia inline temp sensor
1 x Aquero 5 Pro fan controler
1 x EK cup high flow block
1 x EK hd 6870 full block
1 x EK standard high flow vga block
1x MOSAF Block
1 x Aquacomputer aquerio block ( for aquero 5 pro )
6 x 120mm fans in push pull config on 360 rad running at 1100 rpm currently
Cpu temp at idle is 32 deg c and maxes out at around 50 when playing crysis 2 on extreeme in 5760 x 1080
loop temp is 27.1 on idle and 32.1 on full load
flow rate is 79 liters per hour or 1.31 litres per min or .3gallons per min ???? is this ok ?
i have used about 5ft of 1/2 in ID 3/8 OD uv tubing with 6 90 degree conectors
1 x I5 2500k
1 x p8p67 pro mb
16gb corsair vengance ram (4x 4gb ddr3)
2 x AMD hd 6870 in crosfire
Can anyone give me some advice on whether i need another pump or other bits ?
Thanks
1x MOSAF Block
1 x I5 2500k
1 x p8p67 pro mb
Thanks
