Problem with graphics card
so just to be clear this isn't a system issue i will give a list of my hardware
intel core i5 750 running at 3.3 ghz cpu
gigabyte GA-P55M-UD2 motherboard
4gb corsair dominator xms3 1600 mhz ram
Nvidia gts 250 1gb
450 corsair psu
liquid cooling with 120mm radiator
so, my computer is a custom built one from ibuypower and i've run into some trouble with it, when i boot it up and start to play a game, the framerate is excellent(nfs shift at over 90 fps), but for some reason, after about 20 minutes of gameplay, the game crashes and when i restart it, the game now runs at 12 fps. WTF
i haven't got too many computer games but to be sure i went on cod mw2 to try as well and its the same issue, around 120 fps on a normal day but it just laggs to 20 after turning the computer on for more than 20 minutes.
i have no idea how this happened, still tweaking around the bios looking for an answer, would be great if you guys could help!
13 answers Last reply
More about problem graphics card
  1. have you overclocked the gts 250?
  2. i did but reverted the changes to the lowest settings and there is still no improvement, it's like the graphics card is on a continuous idle process
  3. thats really weird, i had the same problem with my gts 250 but i just backed off the clock speeds a bit and it was fine.
    i have no idea, maby someone else can help.
  4. CPU / GPU temps ?
  5. does it only happen with games, have you tried running furmark?
  6. cpu ~25 degrees idle ~40 degrees load
    gpu ~43 degrees idle 50-65 degrees load
    a noticable thing is that gpu-z picks up that my card runs at 300 mhz core and 600 mhz shader and 100 mhz memory when the slowdown starts
  7. so when you reboot it automaticlly underclockes your card, that sounds like an overclocking software issue? maby you should check all your softwares for overclocking, maby you should uninstall and reinstall you drivers.
  8. ah well now that you say that, this happened after i installed the v195.81(i think) version of the dispay drivers
    i'll try again with fresh drivers
  9. another thought, flash you video card bios. maby one of these will work.
  10. solved.... it was the drivers
  11. wait nvm the problem is still there :(
  12. how do i flash my graphics card bios?
Graphics Cards Games Graphics
