Radeon HD 4870 running very inconsistant fps
Hi I play Counter-Strike: Source and I have a Radeon HD 4870 with the newest driver, and it still runs very inconsistant my fps ranges from 20 - 140. I can't figure out whats happening. My setting aren't even set to max.
REsoultion: 1280 x 720
Aspect Ratio : 16: 9
Model Detail: Low
Texture Detail: Low
Shatter Detail: Low
Water detail: simple
Shadow detail: low
Color correction: Enable
Antialiasing: none
Filter mode: Trilinear
Wait for vertical sync: Disable
High dynamic range: None
Can some one tell me whats going on with my gpu? Or help me to make it mor consistant? Thanks for all your help!
9 answers Last reply
More about radeon 4870 running inconsistant
  1. With that card, graphics details and resolution, the most likely culprits are the CPU, drivers or PSU.
    What's the rest of your system like?
  2. COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel , SECC Chassis ATX Mid Tower Computer Case
    Western Digital Caviar Blue WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
    LG 22X DVD±R DVD Burner Black IDE Model GH22NP20
    SAPPHIRE 100259-1GL Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
    G.SKILL 2GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory Model F2-6400CL5S-2GBPQ ( 2x)
    GIGABYTE GA-EP45-UD3L LGA 775 Intel P45 ATX Intel Motherboard
    Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core Processor Model BX80562Q6600
    CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7
  3. Also to the best of my knowledge everything is up today including my mobo as far as drivers go
  4. I don't have Counter strike to know if that is poor performance, but I'd expect that it is.
    I'd check in your device manager and look for anything not working properly or conflicts.
  5. Try turning all of those settings up to high and see if you FPS suffers or stays about the same.
  6. Ya its still flux'ing a lot
  7. That is odd as CS:S is not that difficult a game to run seeing as how old it is.
    What happens when you run it at max settings?
  8. its fluctuating still , low is around 60 - and high is around 120.
  9. Well that is normal. Turn on v-sync or set the fps_max or max_fps command to more suitable ceiling.
    The lows were what was concerning with it being 20fps but if you are getting 60fps low then that is fine enough.
Radeon HD FPS Graphics
