So I'm getting the Gigabyte GA-P55A-UD3 motherboard which can be found here: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128412&Tpk=gigabyte%20ga-p55a-ud3
I have a few questions
Onboard Sound
Now it says audio is 8 channels. Does this mean I can get 7.1 surround sound?
S/PDIF
What is S/PDIF?
There's one optical and one coaxial. What are these? What's it used for and all?
Max LAN Speed
It supports 10/100/1000 Mbps, anyone mind educating me on this some?
Onboard USB
What is this exactly? It already has 10 USB ports, it also has 4 more onboard? How does that work?
Thank you for your time
Onboard Sound
S/PDIF
What is S/PDIF?
Max LAN Speed
Onboard USB
