After some research on the WD TV Live and the Patriot. I have found that building a HTPC would be the way to go. The WD can't play 1080p with 30fps (only 1080i). The Patriot doesn't support FLAC. Little things like this bother me and I know that with a PC I can do whatever I like to make things work: codecs, software, etc...
I want to build a PC that can play 1080p mkvs and 1080p bluray discs seemlessly (I plan on purchasing a bluray drive). The only problem is I do not know what does most of the work. Is it the GPU or the CPU??
I will be running windows 7 and be using VLC (most likely) as the player. This will be on a 47" Vizio TV.
I'm not sure what I need though. I know I don't need over the top Quad core with top of the line GPU right?
Is a dual core with a decent intergrated GPU good enough? Please help. I don't even know how the GPU and CPU decide whos going to do what.
Thanx guys
Thanx guys
