Hello all, I would like to ask the water cooling pro's for some help with this current build I am working on, this will be used for Gaming and general applications with a Overclock on CPU, GPU.
Parts List:
CPU I5-3570K http://www.newegg.com/Product/Product.aspx?item=N82E16819116504
Asrock OC Formula http://www.newegg.com/Product/Product.aspx?item=N82E16813157328
16gb Corsair Ram http://www.newegg.com/Product/Product.aspx?item=N82E16820145347
GTX 670 FTW http://www.newegg.com/Product/Product.aspx?item=N82E16814130824
256gb SSD Boothttp://www.newegg.com/Product/Product.aspx?item=N82E16820147138
Lanboy Case http://www.newegg.com/Product/Product.aspx?item=N82E16811129092
Recon 3D SBlaster http://www.newegg.com/Product/Product.aspx?item=N82E16829102042
Corsair PSU http://www.newegg.com/Product/Product.aspx?item=N82E16817139015
Parts that need Cooling
CPU 77\95 OC tdp
GPU 150\180 OC tdp
Asrock NB cooler built into mb ??tdp
water pump?? tdp
so I was looking at this and thinking a 240 or 360 fan/rad setup with 1 loop should suffice?
Parts List:
CPU 77\95 OC tdp
GPU 150\180 OC tdp
water pump?? tdp
