M mangala Distinguished Feb 5, 2010 1 0 18,510 Feb 5, 2010 #1 some times my vga card produces blurred displays after i re hooked the vga it works properly i do not know weather problem is with the connector or the VGA this happened few times now please help me with this problem
Upendra09 Distinguished Mar 4, 2009 3,174 0 20,960 Feb 6, 2010 #2 open the case and see if there is a loose connection between the jack and the card Upvote 0 Downvote
wa1 Splendid Mar 16, 2009 7,868 1 31,460 Feb 7, 2010 #3 ^+1 also u can try another cable connector, it might be the cable is broke... Upvote 0 Downvote
