Power Supply for CF'ing Radeon HD 5850's
Hello, I need a 600+ watt power supply for crossfiring Asus DirectCU Radeon HD 5850's. I would also like to voltage tweak them and overclock, in addition to overclocking my Phenom II X4 965 CPU and G.Skill Ripjaw 2GBx2 RAM. How many watts would be sufficient for my setup? Also what other factors are there to consider? Please make some recommendations that you feel are best for my build. My case is the Cooler Master HAF 932.
4 answers Last reply
More about power supply radeon 5850
  1. This is the one I have http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009 not that I needed this much power for what I run but its what the store had. Its very good and should run you just fine.
    other than that hit newegg up and go advanced search on power supplies and under SLI type select crossfire ready or certified. You definitely want 750w+ imo.
  2. for the ati setup, you will need a 600W PSU for CF'ing the 5850's since the 600stated wattage is the power req for the whole system, in reality you can run your PC with a 550W PSU
  3. any 600w+ from seasonic, antec, or corsair
Power Supplies HD Radeon Components Product
