Hi, I just recieved my Gigabyte GA-P55-UD3 board for my i7 build, (RMA'd crappy ASUS P7P55D-E LX...garbage) and it seems like
a very solid board for a budget p55 chipset. Anyway I got my i7 860 installed, a Corsair H50 cooler and once I had W7 and all drivers in,
I ran the sensor test on Real Temp, which booted up prime95 and proceeded to load/heat my cpu.
Everything looked fine, the temps were pretty amazing compared to the stock rubbish Intel gave me (sorry wasn't recording, but mid to high 40's and one core at 51'ish?)....I left the room for a moment and when I returned the whole desktop was frozen and unresponsive,
during the second test....!? Like I said, the temps looked fine as far as I can tell.
I have 4 gig of G.SKILL Trident 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL8D-4GBTD
Gigabyte GA-P55-UD3 MOBO, ( using XMP to get the 1600mhz at 8,8,8,24 timings as per what G skill told me )
Corsair H50 cooler, ANTEC 900 case and fans.
Is that Xtreme Memory Profile in effect an overclock? i'm kinda bummed by this as I thought I had built a solid system that I could maybe O.C at a later date.
Am I right in thinking that if it was a heat issue I would get a reboot or a BSOD??
Thanks in advance, and sorry for my noobness.
