Going to buy a new system in a day or two . The main purpose is 3d animation and gaming
Configuration -
CPU : Core i7 860 2.80Ghz
Motherboard : Gigabyte p55 UD2 , MSIGD45 <-- MicroATX
EVGA p55 SLI , MSIGD53 , Asrock p55 pro <-- ATX
( Need to choose a good motherboard With or without crossfire . I dont have a problem with Micro boards at all . Budget is around $100 - $140 )
Memory : Gskill Ripjaw 4GB(2X2gb) DDR3 1333MHz OR crucial 4gb 1333mhz kit
Casing : Antec Two hundred
HD : Samsung spinpoint 1TB
Power supply : Corsair 600W AA (or can i use 500 w supply ??)
GPU : Radeon HD 5750 1 gb
Gigabyte is good and stable board and price is less , good for overclocking . But i have read some bios complains about it .
M leaning a bit towards UD2 , but dont wanna get in trouble after spending the money.
IF any other mobo which is good other than this list plz suggest
Any suggestions and reviews for motherboards would be very helpful ..
Configuration -
