XP Pro Startup Problem - please help
Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
I am currently running a notebook with XP Pro (factory installed). Recently
it started running extremely slow and now it will not even boot up into
Windows. It will begin to start, bring up the XP Pro intial screen then will
give me the following error message: "the procedure entry point
AssocIsDangerous could not be located in the dynamic link library
SHLWAPI.dll." then I get this one: "The log on user interface DLL
msgina.dll failed to load. Contact for sys admin to replace to the DLL or
restore the original DLL."
Being not quite familiar with this I am not sure what to do. I tried to
start up in Safe Mode but it still gives me the same error message. If
anyone can help I would be most appreciative. Thanks.
Fred Stapleton
fabfreddy4@aol.com
1 answer Last reply
More about startup problem help
  1. Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
    Fred,
    See if this applies:
    You receive an "Explorer.EXE - Entry Point Not Found - The procedure entry point SHCreateThreadRef could not be located in the dynamic link library Shlwapi.dll" error message after you install the MS04-038 security update:
    http://support.microsoft.com/kb/888162
    Ramesh, Microsoft MVP
    Windows XP Shell/User
    http://windowsxp.mvps.org
    Using ToolbarCop to remove the unwanted Toolband, Toolbar Icons and BHO:
    http://windowsxp.mvps.org/toolbarcop.htm
    "FStapleton" <FStapleton@discussions.microsoft.com> wrote in message news:DBA58DBB-1806-4F0A-9673-B798863BBD17@microsoft.com...
    Fred Stapleton
    fabfreddy4@aol.com
Configuration Windows XP DLL
