Solved
GeForce GTX 260 OC2 will power supply support this card
hi im upgrading my video card from a 7600 gt to a bfg GeForce GTX 260 OC2 here are my computer specs all i want to know is will this power supply still support my system or should i buy a new along with this video card
Processor: amd athlon 64 X2 6000+
Motherboard: Asus M2n4-sli
ram: 2 gigs
Video card(currently): nvidia 7600 gt
power supply: PEVIA ATX-CW500WP4 500W ATX Power Supply(http://www.newegg.com/Product/Product.aspx?Item=N82E16817148027&cm_re=power_supply_500w-_-17-148-027-_-Product)
Also my mother board is very old should i buy a new mother along with this card any suggestions?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814143198&cm_re=GeForce_GTX_260-_-14-143-198-_-Product graphics card im hopeing to get
6 answers Last reply Best Answer
More about geforce power supply support card
  1. Best answer
    The GTX 260 requires a dual 12v+ rating of 38.
    For example:
    On my Thermaltake Black Widow 550 Powersupply the 12+ ratings are
    #1=17
    #2=18
    making my combined 12+v rating a total of 35.
    It will gladly run the required 25 rating for the GTS 250, but I would like to have at least a Thermaltake 600 watt with the (combined) rated 12+v rail of 48 to run the GTX 260 with power to spare..
    Yes you would definitely want to check into a good 600 Watt PSU as they usually have a better dual 12+v rating to handle the power hungrey 260.
    On a side note, you'd probably be able to run the GTS 250 without needing a new PSU because it only requires a 475 watt.
  2. Thx alot dude im gonna get a new psu then cause im rebuilding this comp slowly cause of money :/ lol so i wanna get the 260 and the case im getting comes with a 750w psu so i think ill just get case and vid card at the same time http://www.newegg.com/Product/Product.aspx?Item=N82E16811129063 the case i was thinking of getting tell me what u think
    WOW. Yes, that should be a case to be reckoned with!
    Good Luck with your upgrade!
    (just so you know, Best Buy had the BFG GTX 260 OC this week for $181.99, sale price not shown on website.)
    What a whole new world you're going to experience going from a 7600GT to a GTX 260.
  4. Alright 1 last question i decided that ima get a comp in like 1/2 a year or so for now im gonna get a 250 so what i was woundering is will this psu support this 250 vid card or should i get one of the other 250 ones
    psu:http://www.newegg.com/Product/Product.aspx?Item=N82E16817148027&cm_re=power_supply_500w-_-17-148-027-_-Product
    250 vid card:http://www.newegg.com/Product/Product.aspx?Item=N82E16814133266
    Also thanks for all yours help dude =D
  5. Yes, that 500w (apevia) PSU will power a GTS 250 just fine...
  6. Best answer selected by filipebow.
Graphics Cards Gtx Power Supplies Support Geforce Graphics Product
