Solved
Newbie to water cooling please help!
My specs right now:
CPU: i5-2500k
GPU: GTX 560 ti SC
Case: Gamma classic series
For Christmas I am going to upgrade my gpu to either a 660 ti or a 670 and my case I am either going to get a CM HAF X or a Rosewill Thor v2.
I would like to water cool my cpu and gpu, I've never done any kind of water cooling so this will be my very first time. I read the sticky and I still don't completely understand everything so I need help getting the necessary parts.
My budget is ~$170 maybe give about $30 - $50. Is cooling my cpu and gpu with this kind of budget possible? If so please tell me good parts that I will need and or a cooling kit.
If you have anymore questions just ask! Thanks!
6 answers Last reply Best Answer
More about newbie water cooling help
  1. Someone help I really need advise and suggestions
  2. Best answer
    CPU only? Yes. Adding GPU? Doubtful. Have you read through the sticky? It discusses some products in those price ranges. If there are items in the sticky you aren't sure of, the first thing you should do is re-read it a few times and then post the questions you are unsure of.
  3. I've read it multiple times now its just overwhelming because this will be my first time so I just want someone to tell me the names of the parts I need to cool my cpu and maybe gpu if that price range is possible. So can someone tell me the names of the parts I should get for my budget? Thanks!
  4. Just giving you the answers isn't going to help you much when it comes time for assembly, cleaning, upgrades or any problems. I realize there is a lot of data, but in all honesty, it's pretty simple stuff once you step back and look at it. Also, we aren't sure what is best for your system and your budget as well as your expectations.
    What you are going to want to look at is the sticky- there are several options listed for beginner kits:
    http://www.tomshardware.com/forum/277130-29-read-first-watercooling-sticky#t1992132
  5. Okay frozencpu.com is having a sale right now I think should I pick up this XSPC Rasa 750 RX240? Also what is dead-water?
    Edit: http://www.frozencpu.com/products/14182/ex-wat-181/XSPC_Rasa_750_RX240_Universal_CPU_Water_Cooling_Kit_w_Updated_Pump_and_RX240_Radiator_and_Free_Dead-Water_BLACKFRIDAY.html
  6. Best answer selected by Jordannn15.
Water Cooling GPUs CPUs Overclocking
