My PC has a start up problem. When I press the power button I get nothing but my USB peripherials power on. After repeated pressing of the power button or sometimes even shutting the PSU power button and putting it back on it will attempt to start but sometimes does not even make it to the bios screen. I had the 4 th core enabled and then went back to 3 cores but still have the same problem. System repair finds nothing and I do not think it is software if I can not sometimes even get to the bios screen. Other times it will start then stop in the middle of trying to load windows I have a Phenom 2 x3 720 Asus mobo M4A78T-E and I just updated it the latest bios. Could it be the PSu, memory or can the board itself be bad. Help. 8 GIgs DDR3 10700 Ram.Problem would occur maybe once every 3 months now happens every time my PC is turned off for a couple of hours. If i just turned it off recently it seems to start okay Thanks
