Will an IFX-14 fit in a Lian Li PC-PC50R case?
Hi guys,
Does anybody know if an IFX-14 will fit in a Lian Li PC-PC50R case? I'm fed up with leaving the side off my current case.
Case:
http://www.ebuyer.com/product/187421
IFX-14:
http://www.overclockers.co.uk/showproduct.php?prodid=HS-069-TR
the Ifx-14 has dimensions of 146 x 124 x 161mm (L x W x H).
the Lian Li case has dimensions of 210mm x 495mm x 490 mm (W, H, D)
Excluding the heatsink, i have 49mm to spare for the case, mb etc.
I'd appreciate any help you can give me please, even if its just a 80% yes (or no).
Many Thanks,
Cameron
1 answer Last reply
More about will lian pc50r case
  1. Anybody got one or know somebody that does?
    The distance from the motherboard tray to the side of the case would be perfect if anybody knows it.
    Cheers
    Cameron
Power Supplies Cases Lian Li Components
