^yeah, i tried, but it didnt work out to well...you are missing an os, so there goes another 105$ to the total. @TomSchwartz, it is not like your budget is impossbile, it is very close, but not quite there, its just that it wont be a very effective gaming machine. also, from what ive seen, going from 700$ to say, 850$ or 900$, makes such an improvement to the build, since at that price everything is only 10-20$ away from each other, but you dont have enough money to upgrade. i have a 900$ (could be lowered a little) build right now ready, much better then what you would get for 700, and it would also last longer, and be more worth the purchase...if you cant bump it up, its still possible, just not worth it, if you can, then great, you would get a much better computer
