This Is going to be my first water cooling build and i was wondering if there was any changes i could make to my planned setup
Phantom 820 Gunmetal http://www.newegg.com/Product/Product.aspx?Item=N82E16811146098
Black Ice GTX Xtreme 360 Radiator or Black Ice GT Stealth 360 Radiator not sure which like how much performance would i lose with the stealth?
Swiftech MCP655-B 12v Water Pump with bitspower pump top modkit
FrozenQ PC Mods 250mm Liquid Fusion V Series
EK Supremacy Universal CPU Liquid Cooling Block - Nickel Plexi
I would like to put UV coolant but i have no idea which coolant reacts well or what UV Lighting to use and same with tubing
