Solved
M2N32SLI: Comment, true or false? Explain if true.
I found this comment regarding M2N32SLI DELUXE WIFI:
v1.0 HAS A PROBLEM IN THE VOLTAGE REGULATORS THAT CAUSE PROBLEMS TO THE MOSFETS WITH CPUs OF OVER 95 WATTS. IT'S ESSENTIAL TO PAY ATTENTION TO ITS VERSION, SINCE v2.0 FIXED VERY IMPORTANT ISSUES WITH THE MOSFETs
¿Has anyone heard something about this? ¿Is it real?
¿How does one check this? ¿Where are those numbers supposed to be?
:ouch: :ouch: :ouch:
5 answers Last reply Best Answer
More about m2n32sli comment true false explain true
  1. Best answer
    Hi aguilacuervo and welcome to Tom's hardware forum.
    1- Where do u found that?
    2- Check the CPU support list for the V1.0 if u can't fing any 125W CPU maybe is true in other case is just a rumor.
    Thanks!
    I found it posted as a comment in this Argentinian auction site: http://www.mercadolibre.com.ar/
    I'm not very sure how does the comment system work there, but...
    Yeah, it's crap... This guy's actually talking about MSI K9A2 CF-F.
    I have no idea how it ended up posted as a comment to the M2N32SLI DELUXE instead.
    Sorry. :whistle:
  3. Well that MSI mobo isn't very good that's why I never bought that and I prefer the K9A2 Platinum.
    Regarding the M2N32SLI Deluxe I don't think that is true.
    Saludos.
  4. No, it will support CPUs up to 125W {e.g. Phenom X4 9850}. However, less expensive MOBO's typically do have an issue if you extreme OC {20-30%+}.
    CPU Support List -http://usa.asus.com/product.aspx?P_ID=0jMy2X8lKstYRvev
  5. Best answer selected by aguilacuervo.
Asus WiFi and Home Networking Motherboards
