Hello!
Just last night I finished my first build ever!
But I have a question on heat issues. I installed the CM Hyper 212+ (with AS5) onto a core i5 750 using an Asus P7P55D-E Pro mobo. Followed the AS5 instructions to the "T" (filling the gaps between the copper heat pipes and the aluminum block, then 'scraped it clean', applied a vertical line of paste on the cpu then let the retention bracket spread the paste on the CPU itself. Now when I did this there was a very small amount of paste that oozed out the side of the processor. It's not touching the back of the chip at all, but this was alarming for some reason. I wasn't happy with the initial application, so I took the HSF off and cleaned both the HSF and the processor, and started over. This time with the exact same results.
So I moved on.
After I got the bios to recognize all hardware / ram etc, I installed Windows 7 64 bit. The instant I updated Windows I ran the Dirt2 demo just to see what my GPU could do (radeon HD 5870). So after about 45 minutes of messing around on that game I went back into my bios to check temps. It stated 37C.
At this point I put my hand on the HSF to check heat. Not even warm. Nothing. The aluminum fins were as cool as the air running thru them. The copper heat pipes weren't even warm to the touch. Is this cause for alarm? or is the cooler just that good? I have it in the HAF 922 (200mm intake fan in front, 200mm exhaust fan on top, and a 120mm exhaust fan directly behind the Cooler.
I have not yet run the Asus mobo disc that came with the mobo. I had a friend help out with the install and he said everything seemed to auto-detect and seemed everything was running fine.
I have not yet ran any test software (CPUZ, Realtemp, Prime95, 3DMark Vantage, etc)
Any thoughts? Input? I'm really not feeling good about this HSF. Seems like it should be getting really hot!
So I moved on.
