Actually, you're not supposed to hit the power button to shut down: you're supposed to hit the "start menu", then hit "shut down" from there (on Windows machines).
The power button is used to turn the machine on (not off), and should only be hit (if the computer is running) if a normal shutdown won't work (because the system is not responding [and you can't solve it with the tash manager]).
