Hey All,
I've been building a system out of some old parts and encountering some difficulties with it loading into bios...
Intel Q6600 2.4ghz FSB 1066
ASRock P43DE3 LGA 775
Corsair DDR3 1600MHz 8-8-8-24
It turns on, thinks for a second, then dies abruptly. The CPU fan spins, HD powers on, everything seems to be working. I think the problem lies with a incompatibility between the CPU's FSB not matching the RAM. If I understand correctly, if I install DDR3 1066 temporarily and then change the multiplier I can speed up the FSB to match 1600 mhz and put back in the Corsair RAM.
Thanks in advance!
Thanks in advance!
