HELP CHOOSE ATI CARD
hi.
I was recently told to purchase an ATI graphics card.
Also so you know I have always used EVGA GTX so i know nothing about ATI.
i will use it for gaming, not worried about maxing everything out. I just don't want lag or slow game play when a lot is happening at once.
guild wars2 / dragons age origins / diablo 3 / AND SUCH
watch movies // Maximum Resolution 1440 x 900 // I will upgrade much later.
i5-750 / asus sabertooth / G.SKILL Ripjaws Series /
must have pixel shader /// I will never use crossfire.
these are the ones i need to choose from. Or around the 200$ mark OR UNDER.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150438&cm_re=xfx_Radeon_2.0-_-14-150-438-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150465&cm_re=xfx_Radeon_2.0-_-14-150-465-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150462&cm_re=xfx_Radeon_2.0-_-14-150-462-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150436&cm_re=xfx_Radeon_2.0-_-14-150-436-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150464&cm_re=xfx_Radeon_2.0-_-14-150-464-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150369&cm_re=xfx_Radeon_2.0-_-14-150-369-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150447&cm_re=xfx_Radeon_2.0-_-14-150-447-_-Product
IF YOU KNOW OF ANOTHER LET ME KNOW ABOUT IT
OR SHOULD I JUST SPEND THE MONEY FOR THIS / <---REALLY STRAINS MY BUDGET
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150442
THANK YOU FOR YOUR TIME
54 answers Last reply
More about help choose card
  1. WITH THE GTX SERIES I KNOW EVGA USES BETTER COMPONATS AND BFG OVERCLOCKS
    WHICH BRAND OF ATI SHOULD I GO WITH? DIAMOND / HIS / SAPPHIRE / VisionTek / XFX ? AND WHY?
  2. The cheapest brand.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814131328&cm_re=5770-_-14-131-328-_-Product
    If they are the same price, Sapphire, XFX, HIS, ASUS, Gigabyte are probably the best.
  3. Since you did present the option of the HD5850, I would go for that. Though it is expensive, you will not have to upgrade your GPU for another 2-3 years, whereas a game might come out that your HD5770 won't play when you buy your new monitor (presumably at 1920x1080).
  4. Forget ATI. I have not used ATI in years because of past driver issues. Step forward ten years....I purchase ATI...problems again. Nothing has changed.
  5. from what ive read most driver issues is because people still have nvidia drivers installed...is this correct?
  6. builderbobftw said:
    Ignore the 5770/5750 cuase that's trash once you turn AA/Hi res/ settings up. Also if you don't mind buying used, the 4890 is 150$ on ebay.
    If you have any evidence of this(doubtful as it's nonsense) then please supply it.
    This guy is talking about 1440x900 and possibly upgrading much later. An HD5770 seems like the perfect choice for that. It's massive overkill at 1440x900 but will still be a good card at up to 1920x1080.
  7. Well, he should spend about 175$ on a 23" moniter that can do 1920x1200 and throw away that craptastic thing he's using now. And if he's on a budget he should buy an 4850x2 or a 4850. Moniters are dirt cheap. I got my 22 inch Samsung moniter at a tech flea market a while agofor 70$ from some dude with a poor grasp of english.
  8. OK GETTING OFF THE SUBJECT I KNOW EVERYONE HAS AN OPINION BUT FACT WISE A 5770 or 5750 WOULD WORK?
    ok what brand has the better quality?
    will this card do me good?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102865
    or
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102868&cm_re=5770-_-14-102-868-_-Product
  9. A MAJOR FACTOR IS I WANT TO STOP THE LAG AND SLOWNESS OF A GAME WHEN 1000 THINGS BLOW UP AND BLOOD SPURTING EVERYWHERE, BODY PARTS HITTING THE SCREEN. ALL AT THE SAME TIME.
  10. Well, since you havbe a crappy moniter, get option 1. Or you could buy a decent mo niter.
  11. I would get this;
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814161317
    and save some money but that Sapphire card would be fine as well.
  12. IF you are going to spend less than that card in my last link I would just get an HD4850. Should still be great for the resolution you are talking about and it's much cheaper than the HD5750 while offering similar performance;
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102824
  13. Cheapor on ebay. But yeh, get a 4850 best bang for buck.
  14. the monitor has to wait cause i just got a plasma tv for the living room. i will not be gaming on it though...sigh eBay Ive had bad experiences.
    like i said i wont overclock or max the res.
  15. however i will be getting a higher res screen in about 7 months....
  16. so get an 4870 x2 off ebay. Paypall should save if someone tries to cheat you.
  17. Yeah, definitely an HD5770 at least if you are going to upgrade the monitor that soon. You could go for an HD4890 instead but personally I wouldn't. The extra 15ish % performance isn't worth the money plus sacrificing DX11 and power efficiency imo.
  18. http://www.newegg.com/Product/Product.aspx?Item=N82E16814131328&cm_re=5770-_-14-131-328-_-Product
    This is the cheapest 5770 on Newegg.
    If you want to spend less go for a 4850.
  19. what about this combo?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16824236063
    ill spend alot more but..from all the arguing i see it sounds like ill be safe doing this
  20. that is the type of monitor i will get.
  21. The 5770 you posted isn't worth it, get mine (unless you want Eyefinity).
  22. http://www.newegg.com/Product/Product.aspx?Item=N82E16814102868&cm_re=5770-_-14-102-868-_-Product
    it runs cool and will be able to handle the monitor, right?
    i want the card to be well made and good warranty.
    i have a 200$ limit on the card however. that's why i need your experiences in helping picking out a well made card that can handle what i give it.
  23. If you're absolutely into quality then Sapphire does have an amazing reputation. The Vapor-X probably also has the best cooling.
  24. it sounds like i should just fork over the the cash and get
    if i do are there any drive problems? or issues? like i said i am new to ATI
    they all have pixel shaders?
  25. If you play games at 1920x1200 with 8xAA then yes.
    If you want a 5850 then this is $10 cheaper.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814161302&cm_re=5850-_-14-161-302-_-Product
    None of the cards have pixel shaders now (from G80 on & from RV670 on), all the shaders are unified.
    If you're talking about pixel shader version then DX10 is SM4, DX11 is SM5, DX9.0c is SM3.
  26. Go for the 5850. it's future proof, in a few years, if you want 3d or Virtual imersion or wahtever goodies the future has to offer, you could always trifire them.
  27. IS H.I.S. A GOOD BRAND?
  28. WHATEVER IS CHEAPEST IS THE BEST BRAND. THEY ARE ALL THE SAME. IF THERE IS ALL EQUAL PRICES GO FOR XXX FOR DOUBLE LIFTIME WARRENTY.
  29. You may want to wait a bit for the HD5830 to be released.
  30. jyjjy, the HD4830 was worse than the HD4770. Repeating history?
    Ruggsy: You have a couple choices. You can buy an expensive card (HD5850), which will leave you set for the next two-three years. OR you can buy a cheap card that MIGHT NOT let you play at 19x10 when yo uget your new monitor.
  31. 19 x 10? You eman 19 X12? Plus if he buys anything under the 5850 he won't be able tio make 19x 12 look nice.
  32. 19x10 = the 1080, the hd screen
    anyway, if i were you, ruggsy, i would save up another hundred or so and go for the 5850, and im pretty sure the price gonna drop once nvidia new cards come out, again, the 5850 will future proof u for a couple years, and then u can xfire it when necessary, but if u really want the card now and with the $200 budget, i strongly suggest the 4890. the 5770 has eyefinity thing, dx11 thing, but it is a lot weaker than the 4890 when gaming, and i dont think u gonna use 3 monitors, are u? plus there are only couple dx11 games for now, even if more dx11 games come out in the very near future, im sure they can run on dx9. so either the 5850 or 4890, the 4850x2 or 4870x2 are nice too if u can get them for cheap, but be sure that you have enough power on your power supply... :) goodluck
    The 4770 was a newer process, higher clocked, and GDDR5 vs GDDR3.
    In this case the 5770 has half the 5830's bus width, both have GDDR5, 5830 has more SP's.
  34. Oh.
    Stupid history not repeating itself, :<.
  35. There are many titles that use the PhysX SDK, but not all include support for PhysX hardware and instead only support Nvidia based GPUs.[17][18]
    [edit] Games
    The following games feature PhysX support (list may be incomplete):[19]
    * 2 Days to Vegas
    * Adrenalin 2: Rush Hour
    * Age of Empires III (Only on the Mac version)
    * Alpha Prime
    * APB
    * Army of Two
    * Auto Assault
    * Batman: Arkham Asylum
    * Backbreaker
    * B.A.S.E. Jumping
    * Bet on Soldier: Blackout Saigon
    * Bet on Soldier: Blood of Sahara
    * Bet on Soldier: Blood Sport
    * Beowulf: The Game
    * Bladestorm: The Hundred Years' War
    * Borderlands
    * Brothers in Arms: Hell's Highway
    * Captain Blood
    * CellFactor: Combat Training
    * CellFactor: Revolution
    * City of Villains
    * Crazy Machines 2
    * Cryostasis: Sleep of Reason
    * Dark Physics
    * Darkest of Days
    * Desert Diner
    * Dragon Age: Origins[20]
    * Dragonshard
    * Dusk 12
    * Empire Above All
    * Empire Earth III
    * Entropia Universe
    * Fallen Earth
    * Fat Princess
    * Frontlines: Fuel of War
    * Fury
    * Gears of War
    * Gears of War 2
    * Ghost Recon: Advanced Warfighter
    * Race Driver: Grid
    * Global Agenda
    * Gluk'Oza: Action
    * GooBall
    * Gothic 3
    * Gunship Apocalypse
    * Heavy Rain
    * Helldorado: Conspiracy
    * Hero's Journey
    * Hour of Victory
    * Huxley
    * iFluid
    * Infernal
    * Inhabited island: Prisoner of Power
    * Joint Task Force
    * Kran Simulator 2009[21]
    * Kuma\War
    * Aura of Wisdom
    * Mafia 2
    * Magic Ball 3
    * Mass Effect
    * Mass Effect 2
    * Medal of Honor: Airborne
    * Metro 2033
    * Mirror's Edge
    * Mobile Suit Gundam: Crossfire
    * Monster Madness: Battle for Suburbia
    * Monster Truck Maniax
    * Myst Online: Uru Live
    * Need for Speed: Shift
    * Nights: Journey of Dreams
    * Nurien
    * Odd Blox
    * Open Fire (and its successor, Open Fire Gold)
    * Parabellum
    * Paragraph 78
    * Pirates of the Burning Sea
    * Prince of Persia
    * Point Blank
    * PT Boats: Knights of the Sea
    * Rail Simulator
    * Red Steel
    * Rise of Nations: Rise of Legends
    * Risen
    * Robert Ludlum's The Bourne Conspiracy
    * Roboblitz
    * Sacred 2
    * Shadowgrounds: Survivor
    * Sherlock Holmes: The Awakened
    * Showdown: Scorpion
    * Silverfall
    * Sovereign Symphony
    * Sonic and the Black Knight
    * Sonic and the Secret Rings
    * Speedball 2
    * Stoked
    * Stoked Rider: Alaska Alien
    * Switchball
    * Trine
    * The Hunt
    * The Stalin Subway
    * The Void
    * Tom Clancy's Ghost Recon Advanced Warfighter
    * Tom Clancy's Ghost Recon Advanced Warfighter 2
    * Tom Clancy's Rainbow Six: Vegas
    * Tom Clancy's Splinter Cell: Double Agent
    * Tortuga: Two Treasures
    * Turok
    * Two Worlds
    * Ultra Tubes
    * Unreal Tournament 3
    * Unreal Tournament 3: Extreme Physics Mod
    * Valkyria Chronicles
    * Velvet Assassin
    * Warfare
    * Warmonger: Operation Downtown Destruction
    * W.E.L.L. Online
    * Winterheart's Guild
    * Wolverine Origins
    * WorldShift
    * Zombie Driver
  36. All those good games like:
    iFluid.
    That sentence doesn't even make sense. That list is of games that use the SDK and a good number of them aren't even PC games FYI. Only a handful of them actually support hardware accelerated Physx(the only thing you need an Nvidia card for) and those games will still play fine on ATI hardware, they just won't be able to use the (usually minimal) bells & whistles of the hardware accelerated Physx. Physx has been around for a long time and as of now there are two games where Physx makes enough of a difference that the gaming experience is better on an Nvidia card imo. Those are Batman: AA and Sacred 2. The very fact that you need an Nvidia card to use it is what prevents Physx from wide adoption by developers and when it is used it's largely cosmetic. DX11 is a much more important feature to have for the future imo.
    that was not written by me. that is what it exactly says on the link. however i thank you for your input. i am having trouble on picking a card. ATI or other.
    i have read a lot of problems with running Dragons age and batman using ATI cards. and a lot of drive issues un-related to old installed nvidia drives still installed. ATI tests and specs are far better than nivida, however i am really confused with the driver issues and the crashing while playing dragons age, batman and guilds wars,sacred 2..
    if you read i want to switch from nivida to ATI. however i am concerned with the mentioned issues.
    i am having a hard time pushing that buy button if you understand, these are an expensive investment.
    i posted the above because i am concerned. no one is explaining it without the DIE HARD FAN INPUT. so as i research, these are the ISSUES i have found. I am completely ignorant when it comes to ATI cards or background. been EVGA all my life.
    So does ATI 5770 still have driver issues with 64 bit windows 7 ?
    will it still crash often while playing games such as dragon age and batman?
    or have severe glitches when maxing out the resolution?
    crossfire issues as well
  39. I have a friend who has an HD5770 and has played through both of those games with no problems(I have an Nvidia card so I can't give any first hand reports.)
    No product is perfect and for almost anything you might buy you will find a small but vocal minority complaining loudly and often if you look for them and my guess is that's exactly what you've done.
  40. PhysX is only hardware accelerated with either a powerful GPU or a dedicated GPU on a small amount of computers.
    Windows Vista SP2+Windows 7 support DX11, that forces GPU's to adopt DX11.
    So developers are looking at the iffy PhysX or the forced-adoption DX11.
  41. Dx11 will be used by both companies this time, though.
  42. I suspect DX11 will end up being adopted much more quickly and extensively than DX10 because there's actually an OS people might want to use that supports it(win7.) DX10 being Vista only had to have made it an afterthought to most developers, probably semi-similar to Physx in that a rather large chunk of their customer base simply couldn't use it.
  43. ok clicked the buy button. Bought the:
    XFX HD-585A-ZNBC Radeon HD 5850 (Cypress Pro) 1GB Black Edition 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported ... - Retail price 229.99$ I hope i choose right.
  44. final build:
    G.SKILL Ripjaws Series 4GB x2 Timing 7-8-7-24-2N
    ASUS SABERTOOTH 55i
    Intel Core i7-860 Lynnfield 2.8GHz LGA 1156
    Samsung 1 TB Spinpoint f3 7200 RPM 32MB Cache
    XFX P1-750B-CAG9 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS SILVER Certified Modular Active PFC Power Supply
    Cooler Master RC-922M-KKN1-GP HAF 922M ATX Mid Tower Case (Black)
    NZXT Sentry LX High Performance Fan Controller (Black)
    Thermaltake SpinQ CPU Cooler
    final price with shipping $1404.11
Radeon Graphics Cards ATI Graphics Product
