I have a HTPC and I want to hide it under the stairs in my closet. My problem is that the power switch has to be pushed for the computer to turn on. I want to be able to just unplug the power cable from the wall (to turn it off!) and plug the cable in to turn it on. I tried using a roll of dimes to keep the power on the front of the case pushed in, but the button has to be pushed in and released for the computer to start. So I thought maybe when the power pins on the mobo make a circuit it starts the computer, so I put a jumper on the power pins and it did nothing. I am looking for a solution to my problem.
Is my best option to buy a push button switch from Radio Shack and run a wire from the case to the edge of my closet that I have to push? Or does someone have a better solution that will involve no button and work by plugging/unplugging the power cable. Thanks.
